Follow up on zyxel vpn tutorial - and soft ether vpn server
hello i'm having the same issue, seems like that the default firewalling rule wins on rules above it.
was there any solution to this old post? (my l2tp rang e does not overlap with anything)
ty
Hi @QuiteSmart ,
Do you mean that it is unable to build l2tp VPN tunnels from lan hosts to Internet?
or your just want to build up l2tp over IPSec VPN to zyxel firewall ?
hi Cooldia thank you for your reply, actually i solved the problem: a firewalling rule ipsec to device didn't allow traffic on 1701 while i was focusing on wan to device rules!
Hi @QuiteSmart ,
Thanks for sharing this information to community user.😀
ipsec to device is also a build in rule in firewall for VPN connection
- 3K Nebula
- 232 Nebula Ideas
- 6.7K Security
- 683 USG FLEX H Series
- 362 Security Ideas
- 56 Wireless Ideas
- 7.1K Consumer Product
- 309 Service & License
- 504 News and Release
- 96 Security Advisories
- 5.1K FAQ
- 89 About Community
- 111 Security Highlight
