Follow up on zyxel vpn tutorial - and soft ether vpn server
2»
  • QuiteSmart
    QuiteSmart Posts: 66  Ally Member
    Zyxel Certified Network Administrator - Nebula Zyxel Certified Network Administrator - Security Zyxel Certified Network Administrator - Switch Zyxel Certified Network Administrator - WLAN
    hello i'm having the same issue, seems like that the default firewalling rule wins on rules above it.
    was there any solution to this old post? (my l2tp rang e does not overlap with anything)
    ty
  • Zyxel_Cooldia
    Zyxel_Cooldia Posts: 1,538  Zyxel Employee
    Hi @QuiteSmart ,
    Do you mean that it is unable to build l2tp VPN tunnels from lan hosts to Internet?
    or your just want to build up l2tp over IPSec VPN to zyxel firewall ?
  • QuiteSmart
    hi Cooldia thank you for your reply, actually i solved the problem: a firewalling rule ipsec to device didn't allow traffic on 1701 while i was focusing on wan to device rules!
  • Zyxel_Cooldia
    Hi @QuiteSmart ,
    Thanks for sharing this information to community user.😀
    ipsec to device is also a build in rule in firewall for VPN connection
