1:1 Nat or Virtual Server
I cannot get this to work. My WAN address is (300.1.1.1) obviously not real. But I need to connect to a Mesenger Server in my LAN with an address of 192.168.1.210 utilizing ports 14121n 14122 and 14123. I have created the following, but cannot get it to work. I have disabled the Windows 10 Firewall to test on the 192.168.1.210 device.
The issue has been resolved using Virtual Server and I had to uncheck NAAAAAAT loopback.
Thank you all
Its Virtual Server you need but I don't think it will help.
Can you packet capture the WAN when the outside connects to those ports like GRC port scan test
https://www.grc.com/x/ne.dll?bh0bkyd2
Good advice there from PeterUK.
Just suggesting, even though it might not be necessary:
Have you checked if UDP packet traffic is needed in your scenario? Or are most UDP ports open in your network between source and target?
Agree with smb_corp_user, you could try to use Virtual Server to obtain the goal.
Agreed with the others, use virtual server. Also, uncheck NAT loopback. I've had some issues with that being checked before - not sure why - so I always uncheck it now.
- 164 Beta Program
- 1.7K Nebula
- 86 Nebula Ideas
- 4.7K Security
- 236 Security Ideas
- 1.1K Switch
- 50 Switch Ideas
- 907 WirelessLAN
- 27 WLAN Ideas
- 5.3K Consumer Product
- 172 Service & License
- 294 News and Release
- 65 Security Advisories
- 14 Education Center
- 911 FAQ
- 399 Nebula FAQ
- 249 Security FAQ
- 90 Switch FAQ
- 100 WirelessLAN FAQ
- 18 Consumer Product FAQ
- 55 Service & License FAQ
- 68 About Community
- 51 Security Highlight
