Port clone
Good morning
ATP800
How do I set one port to be a clone of another?
I'm a novice technician
thank you all for the support
What do you mean by setting one port to be a clone of another? Could you give a specific example?
If you're saying that set up one of the ports to be in the same interface as another, we can do it on the page of Port Group.
Go to Configuration > Network > Interface > Port > Port Group, this page allows the administrator to change the port group, you can drag the icon of the port to one of the interfaces which have another port belong to.Please refer to the screenshots below, here is an example that I try to make port7 to be like port6
After dragging, you can see that port7 belongs to ge6 which port6 also belongs to.
and then you can navigate to port configuration and make sure the speed and the duplex mode are the same for the two ports.
- 220 Nebula Ideas
- 606 USG FLEX H Series
- 482 News and Release
