Multi Subnet and VPN
Nicola_Service
Nicola_Service Posts: 2 image  Freshman Member
edited July 2023 in Security
a customer of mine has a new USG50. connected via VPN IP SEC to headquarters.
It has two subnets
192.1.40.0/24
192.168.36.0/24
I can't set that all traffic from the 192.168.36.0/24 subnet must not pass through the vpn
I'm a novice technician
thank you all for the support
    PeterUK Posts: 4,418 image  Guru Member
    Best I can make out you need a routing rule from LAN to WAN and a rule above that for LAN to VPN for destination subnet.
  • Zyxel_Kevin
    Zyxel_Kevin Posts: 981 image  Zyxel Employee
    Zyxel Certified Network Administrator - Security Zyxel Certified Sales Associate 100 Answers 500 Comments
    Hi @Nicola_Service ,
    Greeting Forum, Please kindly use route-based instead of policy based.
    Please kindly refer the link , the USG part.
    Thank you
