atp700 boot problem
CEDMERATE
CEDMERATE Posts: 3
edited July 2023 in Security
Hi all,
i have a problem with ATP700 after programmed restart , led power is green but sys led is off, i try to connect via RS232 with putty/teraterm but no result, the device is not responding
i could not change boot partition, i don't see any boot string in teraterm.
any idea?
  • Zyxel_James
    Zyxel_James Posts: 788 image  Guru Member
    Zyxel Certified Network Administrator - Security Zyxel Certified Network Administrator - Nebula Zyxel Certified Sales Associate 100 Answers
    SYS LED off means the Zyxel Device is not ready or has failed. As you said the power IED is green which means it was turned on. It could be a hardware issue.
    Please note that the console port setting is correct.
    If the console port is still unresponsive after physically rebooting again, please contact the local RMA center to submit an RMA request for this issue.
  • CEDMERATE
    CEDMERATE Posts: 3
    console setting is correct, but nothing to do, device never responding, is second device ko in same mode in the last 6 months.
    bad quality…..We will evaluate a new brand
  • Zyxel_James
    @CEDMERATE how about pressing the reset button to reset the device? please try
  • CEDMERATE
    CEDMERATE Posts: 3
    This is test :
    turn off device, press hold reset, turn on device, realase button , no result
    with device is on : press reset hold 20 sec, no result
    problem solved by RMA, but before the warranty expires we will buy another brand .. disappointed
