USG 110, remote install printer (autodiscover problem)
kyssling
kyssling Posts: 107 image  Ally Member
First Comment First Answer Friend Collector Sixth Anniversary
Hello, has anyone solved the problem of remote printer/copier installation - when connecting via
SecuExtender is not found device installation program (autodiscover)?
I can manually add the printer and add IP adress printer.
I enabled ports on the firewall: according to table 3 here https://www.cups.org/doc/firewalls.html
So anybody have idea, why AUTODISCOVER search not found device ?
Thank you
  • Zyxel_Cooldia
    Hi @kyssling,
    Based on my understanding, most auto-discovery protocols run in broadcast mode, and broadcasts cannot pass through Layer 3 routing.
    They only work within the same subnet.
  • mMontana
    mMontana Posts: 1,461 image  Guru Member
    Maybe AutoDiscover works only on the same subnet?
  • Zyxel_Cooldia
    Hi @kyssling,
