How do I enable ICMP ping from wan on NR5103E?
Echinida
I have set up ICMP as a protocol under firewall and under acess control set this
| Ping |
| Any/32 |
| Any/32 |
| ICMP |
| Accept | |
However pings are rejected. How can I alow ping from wan?
Enter the username and password to log in to the router's interface. If you haven't changed the default login credentials, consult the router's manual or documentation for the default values. After enabling ICMP ping from the WAN, be sure to save your changes. screen mirroring in built in android This may involve clicking a "Save" or "Apply" button within the router's interface. Within the firewall/security settings, look for an option to enable ICMP or Ping. This might be labeled as "Allow ICMP from WAN" or something similar.
-1 -
- 237 Nebula Ideas
- 6.8K Security
- 740 USG FLEX H Series
- 376 Security Ideas
- 58 Wireless Ideas
- 7.2K Consumer Product
- 319 Service & License
- 512 News and Release
- 99 Security Advisories
- 5.3K FAQ
- 91 About Community
- 119 Security Highlight
