BSOD in PC Windows with wifi
Hi all.
I use a DX3301-TO modem.
When I try to connect my Windows 10 PC to wifi, the PC crashes and shows the BSOD with DPC WATCHDOG VIOLATION.
My wifi adapter is: NIC LAN wireless 802.11ac PCI-E Realtek 8821CE
What can I do?
I have just got a Zyxel router with a new broadband provider and have the same problem
Hi all,
Welcome to the forum.
According to https://learn.microsoft.com/en-us/answers/questions/349623/bsod-dpc-watchdog-violation-windows-10?page=2#answers the cause is likely to be out of date Windows 10 device drivers.
Kind regards,
Tony
Problem solved with a Mini-adapter WIFI USB.
Now all work fine
After a few days, even the new adapter has some problems, in the "rtwlanu.sys" driver.
My modem was changed, but the PC keeps crashing as soon as I activate the wifi0 -
I solved BSOD changing the Zyxel router wifi bandwidth frequency, from 40mhz to 20mhz.
- 222 Nebula Ideas
- 617 USG FLEX H Series
- 53 Wireless Ideas
- 485 News and Release
