GS1350-26HP reset password
melahel
melahel Posts: 2 image  Freshman Member
edited August 2023 in Nebula
HI,
I forgot my user name and password on a GS1350-26HP switch.
How can I reset it ? I tried to hard reset with the small button in face of the switch but each time after reboot I get the same configuration seen with Nebula Control Center and can't login whit the GUI directly to the switch.
Best regards
  • Zyxel_Judy
    Zyxel_Judy Posts: 2,805
    image  Zyxel Employee
    HI @melahel ,
    Your SW is managed by Nebula, so please use the Nebula site password to login your SW.
    Going to Configure > Site settings > Device comigration > Click to eye icon
    Zyxel_Judy
  • Zyxel_Judy
    HI @melahel ,
    Zyxel_Judy
Nebula Tips & Tricks
