VLAN interrouting
I'm on an XGS1930-28hp.
I've configured some VLAN on it.
i'd like to interconnect a VLAN with another one directly on the switch. How can i do ?
thanks
Bests
Thomas
Best Answers
  • Zyxel_Melen
    Zyxel_Melen Posts: 3,448  Zyxel Employee
    Hi @Toulouzzzz,
    I can ping the PC in another VLAN in my LAB. Please reference the handbook chapter 2.2 for the configuration.
    https://download.zyxel.com/XGS1930-28HP/handbook/XGS1930-28HP_2020.1.pdf
    Once the configuration is set, please visit Management > Routing Table > IPv4 Routing Table to check if the routing rule has been set.
    Then use tracert to check if the PC sends the packets to the correct gateway.
    By the way, I was unable to ping once because my laptop was connected to the Wi-Fi network, which caused it to send the packet to the network's default gateway.
    Zyxel Melen
  • Toulouzzzz
    Toulouzzzz Posts: 6
    Find the solution
    Mask problem
    Solved
  • Zyxel_Judy
    Zyxel_Judy Posts: 2,317  Zyxel Employee
    Hi @Toulouzzzz ,
    Could you share with us which management mode you are using, Standalone or Nebula?
    Zyxel_Judy
  • Hi Zyxel_Judy
    A standalone mode.
    I've given an IP adresse to all of the Vlan (10.0.2.254 for the Vlan2, 10.0.3.254 for the Vlan 3...) and a 255.255.255.0 Mask
    I set the first computer (Vlan2) on 10.0.2.1 and gateway 10.0.2.254 and the other one (Vlan3) on 10.0.3.1 and gateway 10.0.3.254. but the first cant ping the other one
    PeterUK Posts: 3,866  Guru Member
    Is their a firewall on the PC's?
  • Oh ! Good point
    I checked on one of the pc but not on both
    I check this tonight.
  • Zyxel_Melen
    edited August 2023
    Hi @Toulouzzzz,
    Are you able to ping after disabling the firewall on both PCs?
    If the problem still exists, please let me know.
    Zyxel Melen
  • Hi
    Still not working.
    I've connectés à Switch on port 5 (Vlan3) with those settings :
    I ve connected my PC on port 1 (VLAN2) with these settings. Firewall is off.
    And here are the IP settings of my switch :
  • Zyxel_Melen
    Hi @Toulouzzzz,
    Zyxel Melen
  • Hi
    Everything is created as u explain.
    The first time I used tracert, the first ping i've sent was sent to the Wifi as u.
    I ve shut down the Wifi on my laptop.
    When I ping my switch (pluggin it directly on the same Vlan) tracert is running well.
    I tried to ping gateway Vlan3 (10.3.0.254) from laptop connected toi Vlan2 (10.2.0.11) and it works.
  • Toulouzzzz
    Toulouzzzz Posts: 6
    Find the solution
    Mask problem
    Solved
