VLAN NAS connected to smart TV
Thanks in advance for your help. I did watch several very good videos on networking but it's just not something I can figure out on my own.
I am especially confused when it comes to things on a VLAN that are meant to connect to things on the routers WIFI.
My goals (see image):
-The PC and The LAPTOP should be able to access and monitor everything on the LAN except for the Work PC.
-The Work PC should have internet access, but otherwise, it's totally isolated.
-The CAMERA reaches the TV via DDNS to Alexa. I'm not sure if I can use my own DDNS and still access Alexa (and the TV). The PC should be able to see the camera using an IP address.
-The NAS needs to connect to the app on the Smart TV, and The LAPTOP, and the PC, but not the Internet.
-The cell phone is on a guess WIFI network.
-I would like to use a non-intra LAN guess WIFI account for Alexa and the Smart TV, but I can't because the NAS needs to see the TV.
-The 2nd router is mainly so I can use the phone and Alexa from the garage and yard.
My questions are:
- Is there a benefit or a need to use the switch's DHCP?
- If I just wanted to set up 2 VLAN's:
1 for the work PC and,
1 for the NAS
How would I do it, and how could I access the NAS from either the LAPTOP or The PC?
BTW, The NAS has a 2nd Ethernet port.
FYI I don't know anything about how to set tagging, untagging or egress so please tell me what each setting should be.
3. Do I need a new (commercial grade) router to put the WIFI devices on a VLAN?
Thanks!
Hi @Syur
GS1200-8 is an L2 Web-managed Switch, it doesn’t support the DHCP server feature.
1 for the NAS
First of all, it's essential to create specific VLAN interfaces on your router.
According to your description, I assume that you would like to have the following VLANs in your network and all the subnets are under LAN1:
- VLAN 1(Default): PC, Laptop, Camera, Smart TV, 2nd Router
- VLAN 10: Work PC
- VLAN 20: NAS
- To isolate your Port 7(Work PC) from the rest of the network, you may set the following security policies on your router:
- Block traffic from VLAN 10 to LAN1
- Block traffic from LAN1 to VLAN10
- To allow NAS to communicate to Smart TV, Laptop, and the PC, excluding the internet, you may set the following security policies on your router:
- Block traffic from VLAN 20 to WAN
For detailed guidance on configuring VLAN for your GS1200-8 web-managed switch, please refer to this article:
This requirement hinges on your current router's capabilities. If it supports VLAN tagging, you can configure the WiFi router’s SSIDs with a specific VLAN. Please consult your router's specification to determine if this is feasible.
Feel free to reach out if you need further assistance.
Kay
- 220 Nebula Ideas
- 605 USG FLEX H Series
- 482 News and Release
