NWA5123-AC-HD Power supply and PoE at the same time?
Hi @Tzunami ,
Absolutely, you can indeed connect both the power supply and PoE (Power over Ethernet) simultaneously to your NWA5123-AC HD access point. When both power sources are connected, the power adapter takes priority over PoE. In other words, the device will draw power from the power adaptor if it is connected, and only if the power adaptor is not connected will it use the PoE source.
Kay
Hi @Tzunami ,
Kay
Thanks, Kay :)
- 439 Beta Program
- 2.8K Nebula
- 200 Nebula Ideas
- 6.3K Security
- 499 USG FLEX H Series
- 323 Security Ideas
- 49 Wireless Ideas
- 287 Service & License
- 457 News and Release
- 89 Security Advisories
- 4.3K FAQ
- 96 Security Highlight
