[Release Note] Access Point Series - V6.60(P2)C0 Release Note
Access Points Firmware Release Note V6.60 Patch 2
Date: August 10, 2023
Overview
This document provides firmware release information on Zyxel Access Points platforms, introduce new Access Points, new features and enhancements, bug fix, known issues and workarounds information for Release V6.60 Patch 2 C0.
Supported Platforms
NWA220AX-6E V6.60(ACCO.2)C0
WAX620D-6E V6.60(ACCN.2)C0
WAX640S-6E V6.60(ACCM.2)C0
New Features and Enhancements
N/A
Bug fix
Mode Bug fix | Cloud | Managed | Standalone |
[eITS: 230600754] [Symptom] When using Nebula cloud authentication, clients unexpectedly disconnect before their set expiry time, with logs showing 'Client disconnected by Apps(ioctl) *User configure in never expired will not encounter this issue | V | ||
[eITS: 230700931] [Symptom] When using AP Live Tool, it might cause all managed AP on the same site disappear in the Access points list from front-end. | V | ||
[SPR: 230717204] [Symptom] 6GHz radio profile with manual channel setup, the channel selection scroll list is empty, no channel entries | V | ||
[SPR: 230612161] [Symptom] When SSID security configure with WPA3-Enterpreise, Intel-7260 cannot connect | V | V | V |
[SPR: 230619202] [Symptom] When configure the SSID VLAN different from AP management VLAN, clients connect to Repeater AP corresponding SSID, network traffic is blocked | V | V | V |
Known Issue
Mode Known Issue | Cloud | Managed | Standalone |
[SPRID: 230511153] [Symptom] When enable MAC- Authentication with accounting, after client roaming, accounting start & stop will exist at the same time (Station still connected to the AP) | V | V | V |
Limitation of Settings
1. Due to hardware limitations, the AP throughput will be limited to 60Mbps when the rate limit, Dynamic VLAN assignment, DPPSK is enabled on NWA220AX-6E, WAX620D-6E, and WAX640S-6E.
Zyxel Nebula Support
where can I download this fw?
Hi @Guldis ,
Hi there,
We've already uploaded the latest FW to the website. To download the latest firmware for your device, you can refer to the Zyxel Download Library. For example, the link provided is for the WAX620D-6E model.
If your APs are managed through Nebula, you can upgrade the firmware by navigating to Configure > Firmware Management.
Zyxel_Judy
- 588 USG FLEX H Series
- 477 News and Release
