Reboot Zyxel GS1200-8 via command
Hello Tobias @tobik176
The GS1200-8 is a Web Managed Switch designed with simplicity in mind, focusing on easy management. It does not support command-based operations such as SNMP or SSH, which are typically used for more advanced manageability.
To meet your demand, please consider other series such as GS1900, GS1915, GS1920, and GS1350 that support SNMP and SSH.
Nami
Nami
Okay thanks, then I will buy a Shelly 1pm to switch power off and on.
I installed more or less 5 of that switches, which when rebooted were working without issues from 1500 to 3000 hours.
Consider to update firmware, if not already done (shortly after the reboot), or inspect your cables. Maybe something triggers the switch in the wrong way.
- 438 Beta Program
- 188 Nebula Ideas
- 6.2K Security
- 454 USG FLEX H Series
- 303 Security Ideas
- 81 Switch Ideas
- 278 Service & License
- 435 News and Release
- 91 Security Highlight
