Zyxel vmg1312-t20b: after updating the firmware, I can't access the web interface
AlexL0123
My device: Zyxel vmg1312-t20b
Current firmware: 5.30(ABSB.2)C0
Issue:
I updated the firmware of my router to version 5.30(ABSB.2)C0 and after that I can't log in to the web interface. When entering the login and password specified on the back of the device, I get the error "wrong login or password"
I downloaded the firmware from this page:
What I've already tried:
- I tried to reset the settings to factory settings several times, but the result is the same: incorrect login or password
- I tried to connect via Telnet, but the result is the same.
- I also tried to enter different login and password combinations that I could find on the Internet (admin:admin, admin:1234, zyuser:1234, etc)
How can I restore the device?
Is there any other way to update the firmware?
I do not know what else to do. Can someone help?
Recommend that you can contact the ISP or retailer for the help logging into your device.
I am having the same issue with my Zyxel AP with the latest firmware, the default username and password which should be admin and 1234, are not working!
- 588 USG FLEX H Series
- 476 News and Release
