XS3800-28 jumbo frame
Smartqwerty
Smartqwerty Posts: 17 image  Freshman Member
Hello
I have an XS3800-28 switch with the latest firmware. How can I enable jumbo-frame for use in one of the vlans (vlan for esxi and storage iSCSI traffic).
  • Zyxel_Melen
    Zyxel_Melen Posts: 4,147 image  Zyxel Employee
    Hi @Smartqwerty,
    But can i check this in switch web or cli?
    » You cannot check the jumbo frame status via web GUI or CLI since it is always enabled.
    And what is maximal MTU? I didnt found this in references.
    » XS3800 supports 12K jumbo frame for 10G and 9K jumbo frame for 2.5G.
    Zyxel Melen
