GS1200-5 VLAN Configuration Question
I am using a GS1200-5 with the V2.00(ABKM.2)C0 firmware.
I am trying to configure the VLAN. On port 5 I have a switch with all management equipment, administration computers and internal trusted access points. Port 4 has internet. Ports 1-3 have untrusted guest access points.
This is how I thought it should be configured:
However, ports 1-3 don't seem to have an internet connection. Ports 1-3 and 5 should have internet, it is just that ports 1-3 should not see devices on port 5. How is this supposed to be configured?
Hi @RyM
First of all, you should make sure that you have created the necessary VLAN interfaces on your router. Following this, since your Port 4 is for the internet(to router), you should tag Port 4 with VLAN10. This tagging will enable devices from VLAN10 to communicate and exchange DHCP packets with the router.
Besides, to isolate your VLAN10 from other VLANs(ex: VLAN1) , do remember to establish the security policies on your router. For example:
- Block traffic from VLAN10 to VLAN1
- Block traffic from VLAN1 to VLAN 10
For more detailed guidance about the VLAN configuration concept for web-managed switches, please refer to this FAQ:
Kay
Hi @RyM
Kay
- 3K Nebula
- 228 Nebula Ideas
- 130 Nebula Status and Incidents
- 6.6K Security
- 648 USG FLEX H Series
- 357 Security Ideas
- 86 Switch Ideas
- 55 Wireless Ideas
- 7.1K Consumer Product
- 304 Service & License
- 496 News and Release
- 94 Security Advisories
- 5K FAQ
- 89 About Community
- 110 Security Highlight
