Several VPN gateways USG FLEX 500
RiKa
RiKa Posts: 8 image  Freshman Member
First Comment Sixth Anniversary
A quick question about the USG FLEX 500. Is it possible to set up several VPN gateways in parallel?
I want to implement the following scenario:
VPN GW1 is set up and running. Users can access the internal LAN via L2TP/IPSEC from their devices.
VPN GW2 is new and should now connect our new office directly to the site-to-site VPN of the head office. A: USG60W > USG FLEX 500
Thanks for an answer
    PeterUK Posts: 4,451 image  Guru Member
    Yes that should be possible.
  • mMontana
    mMontana Posts: 1,469 image  Guru Member
    I'd love to know how it should be, if you can @PeterUK
    edited August 2023
    They have L2TP/IPSEC working for remote devices so all they need is the site to site.
    Here is a run through
    VPN gateway
    IKEv2
    interface WAN1
    peer gateway
    You need to know which end or both to be nailed up Static Address (can use domain name) to connect to the other end or Dynamic Address for the other end to connect to this end to be Site-to-site with Dynamic Peer
    uncheck Enable Two-factor Authentication
    VPN connection
    Nailed-Up on one of the ends
    Site-to-site with Dynamic Peer or Site-to-site depending how you setup VPN gateway
    set your local/remote policy
    routing rules add if needed
  • mMontana
    Thanks for sharing.
