Several VPN gateways USG FLEX 500
A quick question about the USG FLEX 500. Is it possible to set up several VPN gateways in parallel?
I want to implement the following scenario:
VPN GW1 is set up and running. Users can access the internal LAN via L2TP/IPSEC from their devices.
VPN GW2 is new and should now connect our new office directly to the site-to-site VPN of the head office. A: USG60W > USG FLEX 500
Thanks for an answer
Yes that should be possible.
They have L2TP/IPSEC working for remote devices so all they need is the site to site.
Here is a run through
VPN gateway
IKEv2
interface WAN1
peer gateway
You need to know which end or both to be nailed up Static Address (can use domain name) to connect to the other end or Dynamic Address for the other end to connect to this end to be Site-to-site with Dynamic Peer
uncheck Enable Two-factor Authentication
VPN connection
Nailed-Up on one of the ends
Site-to-site with Dynamic Peer or Site-to-site depending how you setup VPN gateway
set your local/remote policy
routing rules add if needed
Thanks for sharing.
- 588 USG FLEX H Series
- 477 News and Release
