Port forwarding USGFLEX200 issue
Hi all,
I am trying to redirect port 7980 to a lan IP of 192.168.1.30
Everything works well on the LAN and the device is responsive on port 80.
However, when I try to access the device from the WAN it looks like the port forwarding is not working correctly.
the broadband in WAN_1 is a dsl line and there aren’t any filter on it.
any advice?
not sure what the problem was but I removed all the NAT rules from the Nebula portal, re-added the only rule I needed for the NVR and it just worked straight away.
Must have been a bug with the Nebula portal.
USGFlex 200 firewall allow connection from wan to port 80 of 192.168.1.30?
Does the firewall on device at 192.168.1.30 read connections from outside the LAN?
yes, device NVR on 192.168.1.30 used to work with exactly the same config with a different router.
anyone that can help here? It must be an issue with either the nebula portal or the firewall.
Sorry… again:
You have a specific firewall rule to allow that?
Side question: USGFlex 200 firewall allow connection from wan on port 7980?0 -
So…if you do NAT 80 to 80 it works but not NAT 7980 to 80?
from my_device on LAN to 192.168.1.30:80 it works perfectly.
From my_remote_device to WAN_IP:7980 doesn’t work.
but does port 80 to 80 work?
could uplink wan1 be wrong for dsl line?
Hi @Carlo
Thank you for the update. If a similar symptom occurs in the future, please inform us.
- 429 Beta Program
- 2.6K Nebula
- 163 Nebula Ideas
- 6K Security
- 350 USG FLEX H Series
- 291 Security Ideas
- 1.5K Switch
- 42 Wireless Ideas
- 6.6K Consumer Product
- 261 Service & License
- 406 News and Release
- 87 Security Advisories
- 3.8K FAQ
- 82 Security Highlight
