SBG3500-N Bridge Mode NTP
MalacakSVK
Hi, I'm using SBG3500-N in Bridge Mode for VDSL connection, this is working fine but I cannot synchronize system time via public NTP server. I know that some routing configuration is required but I cannot find any working configuration. Can anyone help with some tips how to get this to work?!
Tomas
Hi Tomas @MalacakSVK
Welcome to the forum.
I found a user guide at that might be useful.
Some NTP servers have been made not public, because they were being hacked.
You might want to try pool.ntp.org as a NTP server, and configure it in your SBG3500-N under the Time sub menu under Maintenance, see below extract from the user guide.
I hope that this is helpful.
Kind regards,
Tony
- 588 USG FLEX H Series
- 476 News and Release
