FLEX 200 - Disable all licensing
mm_bret
mm_bret Posts: 67 image  Ally Member
edited September 2023 in Service & License
Just fired up a new Flex 200.
Running as on premise mode.
Not interested in Nebula or licensing. Right now they all display "Trial".
I would like to disable all those services. Also hoping when the trial expires, there
is no barrage of warnings, popups etc.
How can I disable ALL optional device licensing eg; WebFiltering, IPS, Application Patrol etc?
Came from USG 1000. What happened to the Firewall? Is it now Security Policy/Policy Control?
Changes are tough….all comments appreciated,
Bret
  • Zyxel_Ivan
    Zyxel_Ivan Posts: 407 image  Zyxel Employee
    Zyxel Certified Network Engineer Level 2 - WLAN Zyxel Certified Network Engineer Level 2 - Nebula Zyxel Certified Network Engineer Level 2 - Switch Zyxel Certified Network Engineer Level 2 - Security
    Dear @mm_bret,
    Hi!
    The license will begin consuming when the registration is complete.
    After the trial license is finished, the optional security service will disabled.
    Now, the 3-in-1 Security Pack for the USG1100 includes Content Filtering, Anti-Virus and SecuReporter.
    I hope this information helps.
    Ivan
  • Zyxel_Ivan
    Dear @mm_bret,
    Hi!
    Ivan
Service & License Help Center
