XGS1210-12 - does is support IEEE 802.3ad?
i just bought this switch to be able to link with RJ45 two giga ports on the XGS1210-12 with an orbi RBR 750 which have two RJ45 giga ports working in lacp.
I have in the web interface create a aggregation port but my router ORBI maked an error : Unable to establish WAN aggregation.
Before buy it, the support informed me that this protocol EEE 802.3ad was supported by the XGS1210-12.
I am doing something wrong or this switch does not support lacp ?
Thanks for your answer
Jeanluc
Hi @Jldavid
The XGS1210-12 switch does not support the LACP (IEEE 802.3ad) function. It only supports the LAG (Static Link Aggregation) feature. For more detailed specifications about the XGS1210-12 switch, you may refer to its datasheet.
If you have any further questions or need assistance with configuring your XGS1210-12 switch, please feel free to reach out.
Kay
Ok so what kind of zydel switch I need ?
I need :
- 2 ports 2,5g
- 1 or 2 ports 10g
- Between 2 and 8 gigabytes ports
Tks
of course with LACP (IEEE 802.3ad) function
Hi @Jldavid
I need :
2 ports 2,5g
1 or 2 ports 10g
Currently, our 10G Multi-Gigabit Lite-L3 Smart Managed Switch, XS1930-10 switch could be a suitable choice for you. For more detailed specifications and information about the XS1930-10 switch, you can refer to this link:
In addition, I have some exciting news to share with you. We are preparing to launch a new model, the 8/16-port Multi-Gigabit Smart Managed Switch, in the near future. This switch will come at a more budget-friendly price point and could be a perfect match for your requirements. Stay tuned! 😃
Kay
- 588 USG FLEX H Series
- 476 News and Release
