Hight channel Utilization
Hi @Jamiewyc ,
Once the DCS is activated, the AP will automatically scan and select the optimal channel in an environment with minimal interference. This eliminates the need for manual channel configuration to mitigate co-channel interference.
Regarding the MAC address displayed on the channel analyzer, it presents the BSSID, whereas Nebula accurately reflects the hardware's MAC address. For instance, in case there is no LAN port on AP, if the hardware MAC address is AA:AA:AA:AA:AA:AA, then the BSSID for the first SSID on radio 1 (2.4GHz) will be AA:AA:AA:AA:AA:AB, and for the first SSID on radio 2 (5GHz), it will be AA:AA:AA:AA:AA:AC. This is based on the rule that the BSSID for the first SSID of radio 1 is the hardware MAC address incremented by 1 in the hexadecimal system, and for radio 2, it's incremented by 2.
There is some rules apply to other BSSIDs of the AP, However, for a detailed view of the BSSID for each AP, we recommend using the following CLI commands is easy to users:
To check the BSSID of radio1:
show wlan slot 1 detail
To check the BSSID of radio2:
show wlan slot2 detail
Zyxel_Judy
Hi Judy,
That's incredibly useful - thank you. Is there any news/comments on the ability to turn off certain bands on individual AP's.
Additionally, can we raise a feature request to show these MAC addresses in Nebula? It would make tracking down interference a lot easier than having to SSH into each AP.
Hi @Jamiewyc ,
We continue to recommend the DCS function for its functionality and convenience. However, if you wish to disable specific bands on individual APs, please refer to the CLI provided below.
Router> enable
Router# configure terminal
Router(config)# wlan-radio-profile RADIO_SETTING_TYPE_2
Router(config-wlan-radio RADIO_SETTING_TYPE_2)# no activate
Please note that to identify the radio profile name, you should refer to the configuration, which can potentially be accessed via the CLI using the command "show running-config”. Btw, the configuration will be overwritten if the AP re-receive the configuration from Nebula due to changing anything else related to radio setting.Additionally, can we raise a feature request to show these MAC addresses in Nebula?
Indeed, the Nebula Idea section is where users can share their suggestions and new idea to enhance our Nebula products and services. Feel free to share your ideas with us and the entire community there.
Zyxel_Judy
- 435 Beta Program
- 176 Nebula Ideas
- 428 USG FLEX H Series
- 298 Security Ideas
- 79 Switch Ideas
- 274 Service & License
- 422 News and Release
- 89 Security Highlight
