Why Nebula does not update to last firmware when adopting new hardware?
GiuseppeR
GiuseppeR Posts: 661 image  Master Member
Zyxel Certified Network Engineer Level 1 - Switch Zyxel Certified Network Engineer Level 1 - Nebula 5 Answers First Comment
edited September 2023 in Nebula
I had this issue also in the past with different hardware.
Anyway, right now I'm creating a new Company inside Nebula and I had to add a dozen of new devices.
For example now I'm adding some APs NWA90AX and also if I say to Nebula to update to latest firmware (at the beginning, via the wizard) it is impossible to get istantly the firmware V6.29(ACCV.1) when adopting new products.
Also if I wait minutes and minutes the Nebula Center notify me that there is an update but it has to be forced to install it.
It seems strange to me.
Nebula Tips & Tricks
