Policy type on clients' list
if I setup some reserved IP using MAC address via "LAN interface" menu (green arrow):
I can't see them listed as "Reserved IP " inside clients' list:
But it seems there that all of those IPs are "Normal" as DHCP is active for everything while it is not.
Is it possible to fix that?
Thanks a lot, as always.
Hi @GiuseppeR
Thank you for contacting us. Could you enable Zyxel support and tell us your org and site name via private message? We would like to check your current settings. Thanks.
Hello @Zyxel_Jeff
I've enabled the remote access you asked me.
I started a ticket support request linking your Nebula nickname.
At your disposal, best regards
- 439 Beta Program
- 191 Nebula Ideas
- 6.2K Security
- 469 USG FLEX H Series
- 308 Security Ideas
- 82 Switch Ideas
- 281 Service & License
- 441 News and Release
- 4.3K FAQ
- 93 Security Highlight
