Double NAT with two USG FLEX devices
Hi all,
i've two USG FLEX connected to each other via Point-to-Point WiFi and IPSec VPN as Backup. Both USG FLEX have it's own DSL connection. All Incoming WAN traffic from USG on the right should be forwarded to the USG on the left and from there to the servers in the DMZ zone.
How to configure the USG's for this scenario (especially the USG on the right)?
Is this the right way or should I forward only specific ports from right to left USG?
Thanks!
Best,
baba
I've gotten to the point where I only want to forward certain ports, but I can't get it configured
Thanks!0 -
What the PC IP that needs the ports from FLEX200 to FLEX200H?
So on the FLEX200 you do a NAT rule Virtual Server
incoming WAN
external IP your WAN IP
internal IP 10.50.10.10
ports
This alone will not work you need to do a static route on FLEX200
destination IP 10.50.10.0
subnet 255.255.0.0
gateway 10.70.70.1
With firewall rule in place that should forward the ports
I've a policy route on flex 200 with 10.50.0.0/16 with GW 10.70.70.1 but it does not work. Must it be a static route?
I don't think a routing rule would work tested here by static route which the NAT rule will follow
You might need a routing rule on FLEX200H
incoming LAN 10.50.10.0
source 10.50.10.0
next hop 10.70.70.2
SNAT none
and maybe on FLEX200
incoming LAN 10.70.70.2
source 10.50.10.0
next hop WAN
SNAT outgoing
Hi @PeterUK the static route does not help :/
source 10.50.10.0
next hop 10.70.70.2
SNAT none
This route would forward all traffic from DMZ (10.50.10.0/24) to 10.70.70.2 but that's not correct. Only when requests comes through 10.70.70.2 response should go back through 10.70.70.2
Best,
baba0 -
Any other ideas?
Thanks!
Best,
baba0 -
do it for 10.50.10.50 then?
Also 10.50.10.50 should have 10.70.70.1 as gateway by default. Only when requests comes through 10.70.70.2 response should go back through 10.70.70.2
- 222 Nebula Ideas
- 617 USG FLEX H Series
- 53 Wireless Ideas
- 485 News and Release
