Double NAT with two USG FLEX devices
baba
baba Posts: 280 image  Master Member
edited September 2023 in Security
Hi all,
i've two USG FLEX connected to each other via Point-to-Point WiFi and IPSec VPN as Backup. Both USG FLEX have it's own DSL connection. All Incoming WAN traffic from USG on the right should be forwarded to the USG on the left and from there to the servers in the DMZ zone.
How to configure the USG's for this scenario (especially the USG on the right)?
Is this the right way or should I forward only specific ports from right to left USG?
Thanks!
Best,
baba
«1
  • baba
    I've gotten to the point where I only want to forward certain ports, but I can't get it configured
    Thanks!
    PeterUK Posts: 4,446 image  Guru Member
    What the PC IP that needs the ports from FLEX200 to FLEX200H?
  • baba
    @PeterUK 10.50.10.50
    So on the FLEX200 you do a NAT rule Virtual Server
    incoming WAN
    external IP your WAN IP
    internal IP 10.50.10.10
    ports
    This alone will not work you need to do a static route on FLEX200
    destination IP 10.50.10.0
    subnet 255.255.0.0
    gateway 10.70.70.1
    With firewall rule in place that should forward the ports
  • baba
    I've a policy route on flex 200 with 10.50.0.0/16 with GW 10.70.70.1 but it does not work. Must it be a static route?
    I don't think a routing rule would work tested here by static route which the NAT rule will follow
    You might need a routing rule on FLEX200H
    incoming LAN 10.50.10.0
    source 10.50.10.0
    next hop 10.70.70.2
    SNAT none
    and maybe on FLEX200
    incoming LAN 10.70.70.2
    source 10.50.10.0
    next hop WAN
    SNAT outgoing
  • baba
    Hi @PeterUK the static route does not help :/
    source 10.50.10.0
    next hop 10.70.70.2
    SNAT none
    This route would forward all traffic from DMZ (10.50.10.0/24) to 10.70.70.2 but that's not correct. Only when requests comes through 10.70.70.2 response should go back through 10.70.70.2
    Best,
    baba
  • baba
    Any other ideas?
    Thanks!
    Best,
    baba
    do it for 10.50.10.50 then?
  • baba
    Also 10.50.10.50 should have 10.70.70.1 as gateway by default. Only when requests comes through 10.70.70.2 response should go back through 10.70.70.2
