Zyxel XS1930-10 web in Deutsch?
Hi @Westlicht,
XS1930 Web GUI does not support German/Deutsch.
Nebula APP supports German/Deutsch.
For iPhone, Nebula APP follows system language, please change it in Settings > General > Language.
For the XS1930 user guide, you can follow the steps below to translate the document:
- Access the switch web GUI.
- Click the "?" help icon on the top of the right.
You will enter the Web Help page.
- Click the translate icon and select the language you want to translate.
- Then you can check it in German/Deutsch.
If your XS1930 is controlled by Nebula, you can check the user guide on the Nebula help center.
Zyxel Melen0
XS1930-10 Web-GUI ob er auch in deutsch?
Hi @Westlicht,
Zyxel Melen0 -
Danke schön,
Prima dann werde ich bestellen den XS1930-10 .
Perfekt
- 435 Beta Program
- 176 Nebula Ideas
- 425 USG FLEX H Series
- 298 Security Ideas
- 274 Service & License
- 419 News and Release
- 89 Security Highlight
