Zyxel XS1930-10 web in Deutsch?
edited November 2023 in Nebula
Hallo, ist der App auch in deutsch?
Nebula Mobile App
und Bedienungsanleitung wo kann ich in Deutsch finden?
danke
Welcome!
It looks like you're new here. If you want to get involved, click on this button!
  • Posts: 3,194  Zyxel Employee
    Hi @Westlicht,
    XS1930 Web GUI does not support German/Deutsch.
    Nebula APP supports German/Deutsch.
    For iPhone, Nebula APP follows system language, please change it in Settings > General > Language.
    For the XS1930 user guide, you can follow the steps below to translate the document:
    1. Access the switch web GUI.
    2. Click the "?" help icon on the top of the right.
      image.png You will enter the Web Help page.
    3. Click the translate icon and select the language you want to translate.
    4. Then you can check it in German/Deutsch.
    If your XS1930 is controlled by Nebula, you can check the user guide on the Nebula help center.
    Zyxel Melen
    Hi @Westlicht,
    May I know what help you need?
    Nebula Mobile APP or XS1930-10 web GUI?
    Zyxel Melen
  • XS1930-10 Web-GUI ob er auch in deutsch?
    Hi @Westlicht,
    Zyxel Melen
  • Danke schön,
    Prima dann werde ich bestellen den XS1930-10 .
    Perfekt
Welcome!
Welcome!
