Double NAT with two USG FLEX devices
2»
    PeterUK Posts: 3,799  Guru Member
    But you want the traffic to go over the wifi to FLEX200?
  • baba
    baba Posts: 280  Master Member
    No, the FLEX 200H should act as main router. Only some clients should be also reachable via double NAT through FLEX200.
    edited September 2023
    The setup I gave is where you don't double NAT but if you need to do double NAT.
    NAT
    FLEX200
    incoming WAN
    external IP your WAN IP
    internal IP 10.70.70.1
    ports
    NAT
    FLEX200H
    incoming interface of 10.70.70.0
    external IP your 10.70.70.1
    internal IP 10.50.10.50
    ports
  • baba
    It also does not work with second NAT rule on 200H :/ I can see the request via traffic-capture on USG shared vlan but not on the vlan where the server (10.70.70.1) is in
  • baba
    Got it! Need "only" one NAT and one Policy Route with snat outgoing-interface at FLEX 200 on the right and a security policy on the left USG
