Nebula and L2TP over IPSec on Ubuntu
Peppino
Peppino Posts: 165 image  Master Member
First Comment Friend Collector Seventh Anniversary
edited September 2023 in Nebula
Can anyone tell me what is the cipher combination used in Nebula, when someone wants to connect to an NSG via L2TP?
Is it 3des-sha1-modp1024 (3DES, SHA1, DH2) and 3des-sha1 (3DES, SHA1) or something else?
Just found out it is like that. I had to wait 1-2 minutes until the pass was overwritten.
  • Zyxel_James
    Zyxel_James Posts: 788 image  Guru Member
    Zyxel Certified Network Administrator - Security Zyxel Certified Network Administrator - Nebula Zyxel Certified Sales Associate 100 Answers
    It should work fine with
    Phase 1 Algorithms: 3des-sha1-modp1024
    Phase 2 Algorithms: 3des-sha1
    Could you uncheck PAP from the PPP settings and try again?
    Moreover, is your device behind NAT?
  • Zyxel_James
  • Peppino
    Hi James,
    I got it going, thanks!
Nebula Tips & Tricks
