Secureport device list empty for other admin
2»
  • Zyxel_Ivan
    Zyxel_Ivan Posts: 387  Zyxel Employee
    Zyxel Certified Network Engineer Level 2 - WLAN Zyxel Certified Network Engineer Level 2 - Nebula Zyxel Certified Network Engineer Level 2 - Switch Zyxel Certified Network Engineer Level 2 - Security
    Dear @StouAdmin,
    Sorry for the misunderstanding.
    1. Can you share the screenshot of the 3 dots (more) and organization/devices, the list is empty ?
    2. There's only the device owner can purchase the license in the Marketplace, and there are no admins in the Marketplace. We'd like to know if any material from us misleading you.
    Thanks.
    Ivan
  • StouAdmin
    StouAdmin Posts: 19  Freshman Member
    edited September 2023
    Login to https://secureporter.cloudcnm.zyxel.com/new-srpt/dashboard
    And tap
    in the right corner.
    Tap
    Tap
    Fill out
    Fill out
    Then it looks like this.
    When user (admin) then logs in to
    located below
    and clicking
    the list empty.
  • StouAdmin
    regarding the license renewal, I(we) can live with that. but the device list should contain the devices the user(admin) has under the organization the user is admin fore.
    at least for easy reading of when a device needs to be renewed.
    thx.
    Kenneth
  • Zyxel_Emily
    Zyxel_Emily Posts: 1,435  Zyxel Employee
    Hi @StouAdmin,
    Here is the definition of Organization and Device on this page for your reference.
    Organization: It shows the organization that you have privilege to see the log/report. As you see, the owner is not your myZyxel.com account but other owners. Click on the organization name and you can see the serial number and MAC address of the device. ⇒ You are not the device owner.
    Device: It shows the devices that are registered by your myZyxel.com account. ⇒ You are the device owner.
  • StouAdmin
    so it's only the owner that can see devices under the device list, and only the owner that can do firmware updates.
    Case closed
    Kenneth
  • Zyxel_Emily
    Hi @StouAdmin,
    Actually, you cannot do firmware updates on "SecuReporter portal" no matter you're the device owner or not.
    If the device is managed by nebula and you have "full" privilege of the organization (the privilege setting is configured on nebula portal), you are able to do firmware updates on "nebula" for the devices even if you're not the device owner.
