Secureport device list empty for other admin
Dear @StouAdmin,
Sorry for the misunderstanding.
- Can you share the screenshot of the 3 dots (more) and organization/devices, the list is empty ?
- There's only the device owner can purchase the license in the Marketplace, and there are no admins in the Marketplace. We'd like to know if any material from us misleading you.
Thanks.
Ivan
Login to
And tap
in the right corner.
Tap
Tap
Fill out
Fill out
Then it looks like this.
When user (admin) then logs in to
located below
and clicking
the list empty.
regarding the license renewal, I(we) can live with that. but the device list should contain the devices the user(admin) has under the organization the user is admin fore.
at least for easy reading of when a device needs to be renewed.
thx.
Kenneth
Hi @StouAdmin,
Here is the definition of Organization and Device on this page for your reference.
Organization: It shows the organization that you have privilege to see the log/report. As you see, the owner is not your myZyxel.com account but other owners. Click on the organization name and you can see the serial number and MAC address of the device. ⇒ You are not the device owner.
Device: It shows the devices that are registered by your myZyxel.com account. ⇒ You are the device owner.
so it's only the owner that can see devices under the device list, and only the owner that can do firmware updates.
Case closed
Kenneth
Hi @StouAdmin,
Actually, you cannot do firmware updates on "SecuReporter portal" no matter you're the device owner or not.
If the device is managed by nebula and you have "full" privilege of the organization (the privilege setting is configured on nebula portal), you are able to do firmware updates on "nebula" for the devices even if you're not the device owner.
- 439 Beta Program
- 2.8K Nebula
- 198 Nebula Ideas
- 6.3K Security
- 484 USG FLEX H Series
- 319 Security Ideas
- 83 Switch Ideas
- 46 Wireless Ideas
- 284 Service & License
- 451 News and Release
- 4.3K FAQ
- 93 Security Highlight
