Policy type on clients' list
GiuseppeR
GiuseppeR Posts: 661 image  Master Member
Zyxel Certified Network Engineer Level 1 - Switch Zyxel Certified Network Engineer Level 1 - Nebula 5 Answers First Comment
if I setup some reserved IP using MAC address via "LAN interface" menu (green arrow):
I can't see them listed as "Reserved IP " inside clients' list:
But it seems there that all of those IPs are "Normal" as DHCP is active for everything while it is not.
Is it possible to fix that?
Thanks a lot, as always.
Nebula Tips & Tricks
