Router DX5301-B2 - USB file sharing acros SMB v2/3
jtwilson
jtwilson Posts: 1 image  Freshman Member
I have this router from the B4RN ISP. I am trying to set up file sharing for video files on an USB connected SSD drive connected to the router. I can see the folders on the USB and have set up sharing on the router GUI.
Is the OS of the router Linux?
Should it connect via SMB v2 or v3, or is it accessible using another protocol. I dont want to use DLNA plug & play. TIA
  • Liba
    Liba Posts: 211 image  Master Member
    First Comment First Answer Third Anniversary
    I think you can ask B4RN ISP about this question.
