[NEBULA] Statistics and log
Hi.
Im trying out an Nebula AP, and is pretty satisfied. However the log and statistic isent to great.
Im looking for website visits from each client. The event log or the summary report, does hot show these things.
It would be great to have, so you could follow each user more correctly.
Hi @Mikethk , welcome to the Nebula community! We are really happy to hear that you are satisfied with Nebula
For traffic monitoring, you need to register a Nebula Security Gateway (NSG) which comes bundled with Nebula Security Service (NSS) one year license, providing Application Monitor that shows the most used applications in the whole network. NSS also provides Application Patrol that allows you to create application profiles and apply them to a specific network. Within the application profile configuration, it is possible to enable logs and the Event logs will display which are the IP addresses accessing those applications defined into the profile.
But so far I haven't seen something as @Mikethk is describing0
@Mikethk @Iwannaquitthegym true, at the moment NCC only provides event logs for application defined in application and the application monitor.
Mikethk, would you mind to give more details about your idea in the IDEA section of our forum? I can also help you to re-post your first comment if you allow me
Do whatever you need Nebula_Bayardo.
I will post it in ideas.0
- 440 Beta Program
- 292 Service & License
- 4.6K FAQ
