VPN100 forward 443
Patryk
Patryk Posts: 3 image  Freshman Member
Policy Control
NAT
WWW
Chrome
Why can't I forward port 443? If I change the external one to 4433 , there is no problem.
    PeterUK Posts: 4,446 image  Guru Member
    edited October 2023
    Maybe your ISP does not allow you to have 443? can you do a packet capture on the WAN and port scan 443 on GRC.com ShieldsUP!
  • Patryk
    If I leave router web gui on 443, I can log in to router without any problems. It's probably not an ISP problem.
    edited October 2023
    Then your NAT rule for incoming interface might be wrong?
    or as your using PPP maybe the port 443 don't work for NAT? with the GUI on port 4443 and NAT rule for 443 dose a reboot make it start working?
  • Patryk
    You were right, it's the ISP's fault. When I changed to the second WAN, it suddenly started working... I don't know how I checked it before. Thanks!
