User name "undefined" when erasing it in Cloud Authentication
GiuseppeR
GiuseppeR Posts: 464  Master Member
Zyxel Certified Network Engineer Level 1 - Switch Zyxel Certified Network Engineer Level 1 - Nebula First Comment Friend Collector
I would like to highlight that I see "undefined" insted of the name of the user when I delete that user inside Cloud Authentication in Nebula webpage.
I think this is a UI typo.
At your disposal
  • Zyxel_Melen
    Zyxel_Melen Posts: 3,791  Guru Member
    Hi @GiuseppeR,
    Thanks for informing us about this problem, this can be reproduced in my org/site.
    I keep you updated once we fix it.
    Zyxel Melen
  • Zyxel_Melen
    Hi @GiuseppeR,
    I consulted with our engineer, and it appears that the term "undefined" should be replaced with "user(s)/MAC(s)," depending on the specific page you are viewing. We will adjust it according to our specs.
    Zyxel Melen
  • Zyxel_Melen
    Hi @GiuseppeR,
    We have updated the wording. Please check the screenshot below:
    Zyxel Melen
Nebula Tips & Tricks
