GS2200-24 configuration files to reset the device
Hi
I have purchased a 2nd hand gs2200-24 switch with no login details. So need to reset it to the factory default, which I have read requires me to upload the original configuration file.I haven't managed to find this file anywhere online, So any help with this would be much appreciated.
Thank you.
Hi @Rayzzy,
Please find the ROM file in the private message I sent to you.
Refer to this FAQ to factory default your switch.
Zyxel Melen0
Hi @Rayzzy,
Zyxel Melen0 -
Thank you so much for the very prompt reply and the file as requested.
Dear Zyxel Support, could you also kindly send me the GS2200-24 configuration reset ROM-file? This cannot be found from anywhere.
Thank you in advance!
Hi @frank_2s,
I have sent the file to you via private message. Please check your inbox. Thanks.
Zyxel Melen0 -
Hi @MISNetworks,
Please click this link to download the latest firmware file, which includes the rom file.
Zyxel Melen0
- 439 Beta Program
- 330 Security Ideas
- 49 Wireless Ideas
- 290 Service & License
- 4.6K FAQ
