Current Version of SecuExtender for Mac not supported on MacOS 14 Sonoma.
End of Octobre ?! It is a joke ? (and it is not funny)
It is unbelievable….
2 -
I understand the only way to be able to work is going back to the previous IOS and wait for the update from Zyxel…
Thanks a lo for the service by the way…
I hope that the solution will be ready tomorrow or at the beginning of next week at the latest. I still find it quite sobering that you only get a solution 6-8 weeks after a publication upon request. Apple released developer versions after WWDC and the problem has been known ever since.
I am patiently waiting for this update also to connect to our 7 VM Ware Servers Remotely on our VPN Secure Network for our 5 Companies- The Buchans Group- Scotland UK- www.buchans.net. please update me when this is released my e-mail is: jack@buchans.net and mobile is: +44-7545-112233. Hopefully its available very soon!!!😁
Hello, it's been quite a while since the Sonoma version was released, and we still don't have a macOS version. We paid for this version, and we can't use it right now.
SecuExtender 1.2.6 has been released, please refer to this
3 -
YES! Finally!
Donwloaded, installed and tested: it's working!So good!
Keep up the good work💪
Does not work on my Laptop :
blob:https://community.zyxel.com/ed123161-804e-4372-bf89-7f943da12361Searching in console :
"exception" : {"codes":"0x0000000000000000, 0x0000000000000000","rawCodes":[0,0],"type":"EXC_CRASH","signal":"SIGABRT"},
"asi" : {"libsystem_c.dylib":["abort() called"]},
"exceptionReason" : {"arguments":["-[__NSPlaceholderArray initWithObjects:count:]","3"],"format_string":"*** %s: attempt to insert nil object from objects[%lu]","name":"NSInvalidArgumentException","type":"objc-exception","composed_message":"*** -[__NSPlaceholderArray initWithObjects:count:]: attempt to insert nil object from objects[3]","class":"NSException"},
"extMods" : {"caller":{"thread_create":0,"thread_set_state":0,"task_for_pid":0},"system":{"thread_create":0,"thread_set_state":0,"task_for_pid":0},"targeted":{"thread_create":0,"thread_set_state":0,"task_for_pid":0},"warnings":0},
"lastExceptionBacktrace" : [{"imageOffset":993460,"symbol":"__exceptionPreprocess","symbolLocation":164,"imageIndex":3},{"imageOffset":106164,"symbol":"objc_exception_throw","symbolLocation":60,"imageIndex":9},{"imageOffset":16360,"symbol":"-[__NSPlaceholderArray initWithObjects:count:]","symbolLocation":620,"imageIndex":3},{"imageOffset":362360,"symbol":"+[NSArray arrayWithObjects:count:]","symbolLocation":40,"imageIndex":3},{"imageOffset":135740,"imageIndex":1},{"imageOffset":127364,"imageIndex":1},{"imageOffset":347412,"symbol":"NSThread__start","symbolLocation":716,"imageIndex":4},{"imageOffset":28724,"symbol":"_pthread_start","symbolLocation":136,"imageIndex":7},{"imageOffset":7740,"symbol":"thread_start","symbolLocation":8,"imageIndex":7}],
"faultingThread" : 2,
"threads" : [{"id":13207,"threadState":{"x":[{"value":268451845},{"value":21592279046},{"value":8589934592},{"value":37413460115456},{"value":1867869312},{"value":37413460115456},{"value":2},{"value":4294967295},{"value":18446744073709550527},{"value":8711},{"value":0},{"value":1},{"value":8711},{"value":735996},{"value":0},{"value":4398046511104},{"value":18446744073709551569},{"value":8324960336},{"value":0},{"value":4294967295},{"value":2},{"value":37413460115456},{"value":1867869312},{"value":37413460115456},{"value":6162835960},{"value":8589934592},{"value":21592279046},{"value":21592279046},{"value":4412409862}],"flavor":"ARM_THREAD_STATE64","lr":{"value":6708972848},"cpsr":{"value":4096},"fp":{"value":6162835808},"sp":{"value":6162835728},"esr":{"value":1442840704,"description":" Address size fault"},"pc":{"value":6708897972},"far":{"value":8195395056}},"queue":"com.apple.main-thread","frames":[{"imageOffset":6324,"symbol":"mach_msg2_trap","symbolLocation":8,"imageIndex":2},{"imageOffset":81200,"symbol":"mach_msg2_internal","symbolLocation":80,"imageIndex":2},{"imageOffset":42224,"symbol":"mach_msg_overwrite","symbolLocation":476,"imageIndex":2},{"imageOffset":7224,"symbol":"mach_msg","symbolLocation":24,"imageIndex":2},{"imageOffset":515792,"symbol":"__CFRunLoopServiceMachPort","symbolLocation":160,"imageIndex":3},{"imageOffset":509848,"symbol":"__CFRunLoopRun","symbolLocation":1208,"imageIndex":3},{"imageOffset":506924,"symbol":"CFRunLoopRunSpecific","symbolLocation":608,"imageIndex":3},{"imageOffset":374680,"symbol":"-[NSRunLoop(NSRunLoop) runMode:beforeDate:]","symbolLocation":212,"imageIndex":4},{"imageOffset":870232,"symbol":"-[NSRunLoop(NSRunLoop) run]","symbolLocation":64,"imageIndex":4},{"imageOffset":159208,"imageIndex":1},{"imageOffset":64224,"imageIndex":1},{"imageOffset":24664,"symbol":"start","symbolLocation":2224,"imageIndex":5}]},{"id":13209,"frames":[{"imageOffset":7720,"symbol":"start_wqthread","symbolLocation":0,"imageIndex":7}],"threadState":{"x":[{"value":6163968000},{"value":4355},{"value":6163431424},{"value":0},{"value":409603},{"value":18446744073709551615},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0}],"flavor":"ARM_THREAD_STATE64","lr":{"value":0},"cpsr":{"value":4096},"fp":{"value":0},"sp":{"value":6163968000},"esr":{"value":1442840704,"description":" Address size fault"},"pc":{"value":6709141032},"far":{"value":6159302040}}},{"triggered":true,"id":13734,"threadState":{"x":[{"value":0},{"value":0},{"value":0},{"value":0},{"value":16},{"value":4320},{"value":105553172861152},{"value":585},{"value":9171823811868544245},{"value":9171823809161575669},{"value":953181590},{"value":5},{"value":105553175844304},{"value":0},{"value":18446744073709551615},{"value":24},{"value":328},{"value":8324976056},{"value":0},{"value":6},{"value":6164541440},{"value":13575},{"value":6164541664},{"value":105553142399888},{"value":8192},{"value":47},{"value":6164535160},{"value":8239931392},{"value":0}],"flavor":"ARM_THREAD_STATE64","lr":{"value":6709161152},"cpsr":{"value":1073745920},"fp":{"value":6164535024},"sp":{"value":6164534992},"esr":{"value":1442840704,"description":" Address size fault"},"pc":{"value":6708932892,"matchesCrashFrame":1},"far":{"value":4343840828}},"frames":[{"imageOffset":41244,"symbol":"__pthread_kill","symbolLocation":8,"imageIndex":2},{"imageOffset":27840,"symbol":"pthread_kill","symbolLocation":288,"imageIndex":7},{"imageOffset":485968,"symbol":"abort","symbolLocation":180,"imageIndex":8},{"imageOffset":448204,"imageIndex":1},{"imageOffset":444100,"imageIndex":1},{"imageOffset":1666948,"symbol":"__handleUncaughtException","symbolLocation":800,"imageIndex":3},{"imageOffset":145544,"symbol":"_objc_terminate()","symbolLocation":132,"imageIndex":9},{"imageOffset":68252,"symbol":"std::__terminate(void ()())","symbolLocation":16,"imageIndex":10},{"imageOffset":80456,"symbol":"__cxxabiv1::failed_throw(__cxxabiv1::__cxa_exception)","symbolLocation":36,"imageIndex":10},{"imageOffset":80372,"symbol":"__cxa_throw","symbolLocation":140,"imageIndex":10},{"imageOffset":106524,"symbol":"objc_exception_throw","symbolLocation":420,"imageIndex":9},{"imageOffset":16360,"symbol":"-[__NSPlaceholderArray initWithObjects:count:]","symbolLocation":620,"imageIndex":3},{"imageOffset":362360,"symbol":"+[NSArray arrayWithObjects:count:]","symbolLocation":40,"imageIndex":3},{"imageOffset":135740,"imageIndex":1},{"imageOffset":127364,"imageIndex":1},{"imageOffset":347412,"symbol":"NSThread__start","symbolLocation":716,"imageIndex":4},{"imageOffset":28724,"symbol":"_pthread_start","symbolLocation":136,"imageIndex":7},{"imageOffset":7740,"symbol":"thread_start","symbolLocation":8,"imageIndex":7}]},{"id":13848,"frames":[{"imageOffset":7720,"symbol":"start_wqthread","symbolLocation":0,"imageIndex":7}],"threadState":{"x":[{"value":6163394560},{"value":21763},{"value":6162857984},{"value":0},{"value":409603},{"value":18446744073709551615},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0}],"flavor":"ARM_THREAD_STATE64","lr":{"value":0},"cpsr":{"value":4096},"fp":{"value":0},"sp":{"value":6163394560},"esr":{"value":1442840704,"description":" Address size fault"},"pc":{"value":6709141032},"far":{"value":6159302040}}}],0 -
@ldubrois please create a new thread for your problem, we will check it for you, thanks.
Current Version of SecuExtender for Mac not supported on MacOS 15 Sequoia can we have an estimated time of arrival please?
Thanks Jack Buchan
Buchans Group
+44-7545-112233
jack@buchans.net
- 435 Beta Program
- 176 Nebula Ideas
- 428 USG FLEX H Series
- 298 Security Ideas
- 274 Service & License
- 422 News and Release
- 89 Security Highlight
