GS1910-24 & 24hp
Danoutlaw3
Danoutlaw3 Posts: 3
image  Freshman Member
hello I have a GS1910-24 and 3 GS1910-24 hp switches.
I had to factory reset all and all have original firmware which is far outdated. I can’t even configure vlans which I need.
How do I upgrade to current verison? I tried to install it but it says it’s the wrong file.
Please help.
  • Zyxel_Melen
    Zyxel_Melen Posts: 5,111
    image  Zyxel Employee
    Hi @Danoutlaw3,
    Please follow the below steps to factory reset your switches:
    1.) Enter "Ctrl+C", while booting.
    2.) Enter "default" to reset to default.
    3.) Enter "reset" to reboot and wait for config re-generation
    4.) You can find the password and configuration have been reset.
    Please find the correct firmware file in the below post.
    Zyxel Melen
