Changing nat type?
i have this router EMG3525-T50B. my ps 5 shows nat type 3 but i want/need nat type 2.
How can i change it?
Don't know know much about that router you can try port forward UDP 3074 to your ps 5
and how to do it kinda new to this type of stuff
login to your router find port forwarding enter in whats needed like IP of Ps5 and port
but where do i find wich port
Hello @vaikepuu
Welcome to the forum.
I found this post about what you are talking about: https://www.techadvisor.com/article/744513/how-to-change-your-nat-type-on-ps5.html
- This article talks about what UDP and TCP ports are needed.
Section 11.2 of the user guide for EMG series of routers, available at https://spdl.zyxel.com/VMG8623-T50B/user_guide/VMG8623-T50B_1.pdf , talks about where to set-up port forwarding.
You also need to set-up you router so that your PS5 is given the same IP address always or has a static IP address that the port forwarding can point to.
I hope that this is helpful. Do ask if you have more questions.
Kind regards,
Tony
to my router is connected the NR7101 router so if i log into my EMG3525-T50B router and change stuff there will it work?
Hello @vaikepuu
Yes, I think that changing it in the EMG3525-T50B router should be right.
Kind regards,
Tony
- 222 Nebula Ideas
- 616 USG FLEX H Series
- 53 Wireless Ideas
- 485 News and Release
