USG210 - WiFI client unable to reach the DHCP from VLAN
Hi guys, I'm trying to achieve multi SSID network schema with USG210 and NWA5123.
I had follow this example: https://businessforum.zyxel.com/discussion/1631/multi-ssid-how-make-it
But Wifi client can connect to the SSID and cannot get an address from the DHCP Pool.
Please advise:)
Please advise:)
The problem with DHCP was the switch.
But still I cannot get address from the correct vlan. From the WiFi I get always address from the default vlan1. If I try to connect to the same lan of the AP from my laptop with configured vlan (in example vlan10) - I can get address from the correct DHCP from vlan10.
What it can be?0 -
The switch ports connect to USG and AP need to transfer tagged frame in and out for vlan10.
In your case,
client--->SSID (AP)<--->vlan10 tagged frame<--->siwtch<--->vlan10 tagged frame<--> (vlan10)USG
The guiding questions from your side helped me. Thanks a lot!0
- 220 Nebula Ideas
- 605 USG FLEX H Series
- 482 News and Release
