Nebula Setup /AP Setup
Hi
In my setup - I have a usb flex100w connected to Zyxel switch (XS1930-12hp) which my wax 640s AP is connected to. However the AP is online and I can access the internet but within nebula it is showing offline. Physically on the AP - the light is green for two seconds and then flashes orange for a second and then goes back to green. Any suggestions ?
Hi @Gurmstar,
It looks like your AP cannot connect to Nebula, please check
- AP has an IP address and DNS server.
- AP can connect to the router/Internet.
- AP can resolve d.nebula.zyxel.com.
- Firewall doesn't block the protocol 4335/6667.
- There's no IP conflict in your network.
You also can reference this FAQ:
Hope it helps
Zyxel Melen0 -
Hi
thanks - both the switch and firewall are connected to NCC and are managed through this.
the wifi is working and clients can connect - when checking the topology of the network - the wifi clients all seem to be directly connected to the switch rather than the AP which is offline but is providing wifi and connecting clients to the internet through the switch and firewall.
is the ip conflict between switch and AP how would that be resolved?0 -
Hi @Gurmstar,
You can check the event log of your firewall and filter "IP conflict" to check if there is an IP conflict that occurred before.
By the way, could you help enable Zyxel support and provide the organization and site name in PM for me to check?
Please go to Help (On the top of right) > Support Request > Zyxel support Access to enable and save.Zyxel Melen0
- 438 Beta Program
- 188 Nebula Ideas
- 6.2K Security
- 454 USG FLEX H Series
- 303 Security Ideas
- 81 Switch Ideas
- 278 Service & License
- 435 News and Release
- 91 Security Highlight
