Content Filter not working USG Flex 500 issue
andreive
andreive Posts: 3 image  Freshman Member
When i enable Content Filter and(or) DNS Content Filter in Policy Control, http and https connection become very slow. I think that because Content Filter not resolving url(domain name).
in cli:
Router(URL)# https://community.zyxel.com
% ret err = -4
result: Error
The query takes: 1.000000 seconds
in web:
Help me solve the problem, thanks.
  • Zyxel_Jeff
    Zyxel_Jeff Posts: 1,368 image  Zyxel Employee
    100 Answers 500 Comments Friend Collector Fifth Anniversary
    Hi @andreive
    Currently, the Content Filter doesn't provide the Belarus area, we apologize for any inconvenience caused. Thank you for your understanding.
    PeterUK Posts: 4,446 image  Guru Member
    Do you have a DNS set for the Flex to use?
  • Zyxel_Jeff
    Hi @andreive
    Not sure if it is related to your DNS settings. Please navigate to Configuration > System > DNS > Domain Zone Forwarder and add a setting as shown below:
    This will enable DNS queries by the Google DNS server 8.8.8.8. Thanks.
  • andreive
    edited October 2023
    this is my DNS settings:
    and when i change DNS to only 8.8.8.8 auto i have the same issue
    edited October 2023
    If you go to Diagnostics > Network Tool with NSLOOKUP IPv4 and put in grc.com does it resolve?
    If you get tracetcp
    https://simulatedsimian.github.io/tracetcp_download.html
    run
    tracetcp d.myzyxel.com:443
    does it complete?
  • Zyxel_Jeff
    Dear @andreive
    Could you provide a remote Web-GUI link to us for further checking purposes? I will send a private to you later, please check your inbox. Thanks.
  • Zyxel_Jeff
    Hi @andreive
