LTE7490 MTU setting missing
Thank you, it's still a bit weird that MTU as low as 1277 is required for proper image loading on is.fi & hs.fi.
I tried "mturoute -t" command (free tool) to the is.fi image server (after putting client MTU back to the default 1500) where fragmentation happens (if MTU is over 1277), and it says 1464:
mturoute to 52.85.49.80, 30 hops max, variable sized packets
- ICMP Fragmentation is not permitted. *
- Speed optimization is enabled. *
- Maximum payload is 10000 bytes. *
1 +- host: 192.168.2.1 max: 1500 bytes
(steps between 2 and 14 omitted, either not reaching or 1464 bytes)
15 +- host: 52.85.49.80 (image servers on is.fi) max: 1464 bytes
I guess for my PC→image server direction 1464 MTU works while for the opposite direction client MTU must be for some reason exceptionally low, 1277 ?
Attached are wireshark screenshots when MTU is set to 1277 and the images load properly:
So in conclusion:
Client MTU 1277: IPv4 packet total length 1277, TCP, no fragmentation, images load properly
Client MTU 1278-1500: IPv4 packet total length 1420, QUIC, fragmentation, images load very poorly
EDIT: OK! I've confirmed the issue is with my ISP: if MTU is over 1277, QUIC which uses UDP is enabled and my ISP doesn't seem to route it properly.
I tested 2 other ISPs (these are also mobile subscriptions) and with the default client (Windows network adapter) MTU of 1500, everything works great: images load properly, QUIC is enabled with no IPv4 fragmentation and IPv4 packet length is 1480:
Hei,
Millä operaattorilla vikaa esiintyy? Itselläni on sama LTE7490 sekä Elisan liittymä, HS.fi ja IS kuvat toimivat (iPad app), mutta Gmailin viestit ei lataudu iPadin mail-sovelluksella joka kerta. MTU pienennys ZenWifin asetuksista näyttää korjanneen ongelman.
Sorry for writing in Finnish, I don't know English very well.
DNA & Moi has this issue (reported, hope they'll get it fixed), Elisa & Telia are free of this problem.
Therefore your problem has a different cause.
- 602 USG FLEX H Series
- 480 News and Release
