USG FLEX 50W Running 5.37 PPPoE Configuration
Hello Everyone,
On my USG FLEX 50W running 5.37 firmware, my ISP changed me from Ethernet connection to PPPoE connection all of a sudden. That is a long story that I won't go into detail on here. Needless to say I gave them an earful about how unhappy I was losing three days of Internet access because I was not informed of a change being made to my connection.
So, while working with them to get my configuration updated, I could only get the PPPoE active when I also had the Ethernet WAN interface enabled. This seems a bit redundant to me since they are both WAN connection types.
In my original static IP configuration, I had the Ethernet interface (CONFIGURATION > Network > Interface > Ethernet > wan) configured to use a fixed IP address, which was the static IP they assigned to me.
In the new configuration, I ended up having to set the Ethernet interface to "Get Automatically" and also configure the PPPoE interface (CONFIGURATION > Network > Interface > PPP > System Default > wan_ppp) to "Get Automatically" in order for the connection to work. So, rather than the static IP being held by the ZyXEL, they are passing it through to me.
When I initially disabled the Ethernet wan interface thinking they did not both need to be active, the PPPoE connection went down.
I would think the PPPoE interface alone should allow the connection to work without the Ethernet interface being active since they are both "wan" interfaces. Where am I missing the boat on this?
Ethernet wan is the base interface of wan_ppp, so ethernet wan must be enabled.
This concept also works with VLAN interface, the base interface LAN should be enabled when using VLAN.0
This concept also works with VLAN interface, the base interface LAN should be enabled when using VLAN.0 -
Thank you Zyxel_James.
So, the ppp_wan is a sub-interface to Ethernet wan.
I get it now, the tabs on the Interface page are in order of hierarchy from left to right. I missed that layout concept previously.
- 222 Nebula Ideas
- 616 USG FLEX H Series
- 53 Wireless Ideas
- 485 News and Release
