Mixning different ap
saltet
saltet Posts: 54  Ally Member
edited May 2024 in Wireless
i have à system with Nebula and six Nwa 50.
considering upgrading with one or two wax 650 S or wax 640S.
are both these two ap:s compatible with nwa 50 and able to manage with nebula in a mix mesh system.
what are the pro and cons between the two different ap:s.
I know the different between regarding 6 E but I am not sure about the other pros and cons.
  • Zyxel_Judy
    Zyxel_Judy Posts: 2,317  Zyxel Employee
    Hi @saltet ,
    It's great to hear that you are considering upgrading your network with the Zyxel WAX650S or WAX640S-6E. Both APs are compatible with the Nebula system and can be managed alongside your existing NWA50 APs.
    To know about some differences between the two models that might influence your decision, please refer to this thread.
    Zyxel_Judy
    Untitled Image
  • Zyxel_Judy
    Hi @saltet ,
    Zyxel_Judy
    Untitled Image
  • saltet
    Thanks a lot.
    After reading the thread you advise me to read a will go for 650S.
    I think that the mix environment I have will not utilise the 6E for some years.
    Best regards
